check engine light ?
Old Mar 27, 2006 | 06:37 PM
dcjcdc's Avatar
Default check engine light ?
well have the 2002 s40 turbo 1.9 automatic 67,000 kms
- last month the engine light came on only when started the car and after a minute while driving it will go off...even when you turn off the car when warm the light stays on for a kilometer or 2 than off..brought it to my friends place who has when of those gauges obd ..and it read no codes...
just wondering what is going on....
than today my wife said the engine light stayed on,,,looked at the car and she did not have the gas cap closed,,,told her in t he future , close til you hear the click of the gas cap..and the engine light went to how it was befiore when you start the car ,,it comes on,,,also a new light came on which is a check engine light for canadian models...so i wonder from my wife driving with the gas cap loose, could of caused the new light????????
any input would be appreciated
Thanks
Old Mar 27, 2006 | 07:42 PM
dcjcdc's Avatar
Default RE: check engine light ?
well after reading the volvo s40 manuel..that light is service reminder light..light stays on for 2 minutes after start until reset by the servicing retailer...but have to check the other engine light that came on
Old Mar 27, 2006 | 09:37 PM
If you search in the forum here you will find instructions for resetting the service light only.
You will have to have the codes pulled for the Check Engine light.
Old Mar 27, 2006 | 09:43 PM
androide016's Avatar
There are two different lights, one is service light and the other one is the check engine light. The service will come on automatically after 750 hours of use or after 12 month as the manual said, the light will stay on for about 2 minutes after the car starts. Is very simple to reset this light, you can do it as fallowing:
1. Hold down the odometer button
2. Turn the ignition so all the lights come on (on position but dont start it)
3. Keep holding the odometer down for 30 secs or until the service light starts flashing
4. Release the odometer button while service light flashing
5. Turn off and on again to check
regarding the check engine light is posible that can came on if you didnt close the gas cap or didnt adjust it well, so the check engine light should go off after closing well the gas cap, maybe it could not go off instantly but it should go off later if the reason is the gas cap.
Old Mar 28, 2006 | 01:05 AM
gordon368's Avatar
when i use to own my s40, (now own a 2001 s80 t6), when the check engine light would come on like that and shut off(within 2 minutes) it would usually mean that the oil was bad or it needed to be changed...
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
