Check Engine Light and Multiple ECM codes
Old Aug 26, 2013 | 01:20 AM
Xtossin's Avatar
Default Check Engine Light and Multiple ECM codes
Hi...
My 2007 s40 2.4i Volvo Started making a VROOM sound upon acceleration, then I noticed the AC was not blowing cold air...then Check Engine Light Came on!!
Since it was Sunday, I went to Firestone to diagnose it...The mechanic refused to repair it, but gave me some ECM error codes his computer read:
1300- Mass Air Flow Sensor
400- canister Purge Valve
4310- leakage Detected
4350-Leakage detected Heater
6000- AC relay
6400- Cam Shaft Reset
The mechanic said it could be one thing that sets all these codes off...but he has no clue how to fix this.
He suggested I go to a Volvo Specialist, which I do plan on going.
Regardless, I'm eager to go educated to the specialist, any ideas what may be going on, if its something I can do myself? I am pretty handy on DIY work!
The car is not overheating..rpm is normal....I do worry because I Transport my pregnant wife with this vehicle...
Thanks in advance
Old Aug 28, 2013 | 10:06 AM
Hudini's Avatar
I've seen low voltage cause all kinds of problems with the newer Volvos. Check your voltage at the battery for ~12 volts before engine start and ~14 engine running.
Old Mar 19, 2021 | 06:26 PM
Lekart's Avatar
Originally Posted by Xtossin
Hi...
6000- AC relay
Thanks in advance
Hi My Wif'e's car has come up with the same codes as these I know its a long time ago but were you able to get it sorted and do you remember what was need to repair it.
Thanks in advance
Cheers
Craig
Old Apr 1, 2021 | 02:56 AM
Djeader's Avatar
A must-go for a Volvo repair professional
Annette Attilio Walsh
Apr 6, 2019 02:22 PM
Sir Vivor
Apr 13, 2018 05:52 PM
VolvoS40_2.0T
Oct 8, 2008 08:12 AM
jayjuliawells
Apr 17, 2008 08:40 AM
Cypress
Dec 2, 2004 03:18 AM
