Check engine light
Old Apr 1, 2019 | 07:17 PM
Annette Attilio Walsh's Avatar
Default Check engine light
A few days ago my 2007 Volvo S60 check engine light went on. I took it to Volvo & they did an ECM update, replaced defective leak detection pump, & replaced the barometric pressure sensor. Now the light is back on HELP!!!
Old Apr 2, 2019 | 09:04 AM
time to go back to the dealer and have them check the diagnostic codes again. Its probably a good idea for them to also give you a print out of what fault codes were found in the scan. You can also stop by a big box parts store like Autozone and borrow an OBD2 scanner to view the codes yourself (it plugs into a connector under the dash). You can then google the codes or post to the forum to get some feedback.
Old Apr 2, 2019 | 10:03 AM
Larry Beria's Avatar
Let's hope you forgot to tighten the gas cap. Autozone or Advance Auto Parts can read your codes for free.
I would recommend getting a $15 obd2 scanner and keeping it in the glove box. You can read the codes anytime instead of panicking.
Here is a great article that can help you understand and troubleshoot Volvo check engine light yourself.
Old Apr 6, 2019 | 02:22 PM
eevolvo's Avatar
I agree that it is time to take it back to the dealer. Tell the dealer that you paid them fix a problem and it has returned. They should fix that.
Kathleen Williams
Jan 26, 2019 09:26 AM
peterz
Dec 8, 2013 07:07 PM
Capo Cam
Mar 15, 2008 04:59 PM
Musicjunkie2k
Oct 22, 2005 07:27 PM
Cypress
Dec 2, 2004 03:18 AM
