cigarette lighter
Old Mar 20, 2008 | 10:33 AM
emek's Avatar
Default cigarette lighter
has anyone ever had a cigarette outlet (12V) problem. Mine is not working at all (no light, no power). First thingI checked was the fuse. It's fine. Any hint would be helpful. Thanks.
Old Mar 24, 2008 | 06:22 PM
rapedaemon's Avatar
Default RE: cigarette lighter
pull out the lighter and hook the wires up to a multimeter, check volts from wire to a ground, if you have power than it's your device, if no power, check your wire again and if all looks fine, just run another from your fuse panel to the device
Old Jun 20, 2008 | 12:09 PM
mjbdj's Avatar
I had the same issue and luckily it was only a blown fuse.
Old Jun 20, 2008 | 12:58 PM
nkachrani's Avatar
what fuse should I look at? I have a 2004 S60?
Old Jun 21, 2008 | 06:36 PM
chimmychong's Avatar
for some reason my cig lighter's fuse burns out every so often
newtome
Sep 25, 2007 07:47 PM
m_schiff83
Aug 10, 2007 05:06 PM
biffo19
Mar 1, 2007 08:10 PM
rjgspr
May 5, 2005 01:06 AM
rjgspr
May 3, 2005 10:54 PM
