Cooling Fan . . .
Old Mar 15, 2009 | 05:32 PM
AEWalker's Avatar
Default Cooling Fan . . .
Can someone help me ... I have a 2000 S40 . . . In the last 24 hours when I've been driving my car around for a bit and I turn it off, there is a fan, I think the cooling fan, keep running for a little bit afterwards .....
Has anyone had this happen before? It's never happened to me an I'm a tad concerned about it.
Thanks!
Old Mar 15, 2009 | 06:25 PM
Lyonsroar's Avatar
Check you MAF sensor.
Old Mar 15, 2009 | 06:56 PM
AEWalker's Avatar
What/Where is the MAF sensor??
Old Mar 16, 2009 | 05:27 AM
rupert77's Avatar
Cool
your maf sensor is screwed to the air pipe right beside your airfilter box you cant miss it. It doesent sound as if it is going to cause too much trouble the same use to happen to my last car and i had it 2years, it didnt happen all the time just ocassionally in hotter weather. To be on the safe side keep an eye on your water and coolant levels and see that there is no drop in them ok!!!!
Old Mar 16, 2009 | 03:54 PM
Lyonsroar's Avatar
Well, the other day I accidently ran my car without the MAF plugged in, and when I stopped it, the fan continued running until I plugged it in again.
Just a suggestion.
There is a how-to clean the MAF on s40concepts.net BTW. It's pretty easy to do.
rolandt
Oct 16, 2017 12:24 PM
norasaint
Sep 20, 2012 12:53 AM
elouadj
Jun 25, 2008 07:00 PM
vcolper
Nov 1, 2006 10:20 PM
Carbuff
May 26, 2005 12:01 AM
