couldnt turn the key around to on(start engine) geniune key used
Old Jun 7, 2008 | 03:15 PM
joseangel's Avatar
Default couldnt turn the key around to on(start engine) geniune key used
yesterday i couldnt turn the switch to on position, just i and ii,(everything electrical came on) to start the engine the key gets blocked as if i were using a generic key. a couple of month ago i coulnt remove the key from ignition, but still i could start the engine, so a guy opened it up and remove a clip or wire he told me, so the key was realeased, yesterday was a headache cuz i was really late 2am at a parking garage, fortunately i hitted hard enough the ignition with some pliers tht it finally started. help again plz, i will appreciate it, thnx.
Old Jun 8, 2008 | 06:53 AM
Default RE: couldnt turn the key around to on(start engine) geniune key used
I am starting to see a rash of this lately. The ignition assembly is bad.
Old Jun 8, 2008 | 07:42 AM
chimmychong's Avatar
this has happened 3 times on my s40 randomly
Old Jun 14, 2008 | 12:24 AM
joseangel's Avatar
did u get it fixed?¿ how much did it cost?¿
Old Jun 14, 2008 | 10:27 AM
no I didnt .... hasnt happend in about 2 months....I think it might have to do with the shift ****... just a guess cause sometimes the key wont come out of my s40... this is because my shift **** button kinda gets stuck and when that happens it wont let the key come out....
Old Jun 18, 2008 | 07:18 AM
00 Silver S40's Avatar
I just had the same problem with my s40 after i got the new motor put in it. The problem was that the shift **** was clicking into place. The switch on the shift **** wasnt closing all the way and caused the key to get stuck in the ignition. If it happens again makesure the switch isnt stuck and you should be fine. If that isnt the problem my suggestion is have the ignition assembly replaced.
gentlejax2
Jun 18, 2012 03:19 PM
chrk
Nov 29, 2011 12:25 PM
volvorecycle
Sep 1, 2009 06:48 PM
gary2
Jul 21, 2008 05:53 PM
ciao-rich
Jun 13, 2008 05:01 PM
