couple issues s40 1.6 diesel
Old Jun 8, 2015 | 09:24 AM
s40disel's Avatar
Default couple issues s40 1.6 diesel
recently bought at auction a 2005 1.6 diesel, with 80 k on it.
seems a fairly solid car, but have some engine issues am looking for advice on.
I seem to have a diesel leak, i assume form around the injectors, leaking seals, as have pools of diesel in the cylinder head around the injectors. Can i just pull the injectors, and replace seals, or do i need to re machine the injector seats prior to new seals?
Secondly my turbo isn't spinning up. It does if i work the actuator by hand, its spins up, so the turbo works, but I'm not getting vacuum/pressure to the regulator. is there an obvious place to look for this leak?
Thanks in advance.
Old Jun 9, 2015 | 07:04 AM
s40disel's Avatar
any one, want to fix the injector leak, but not sure what parts or equipment i need
p3autos
Jun 7, 2014 11:28 AM
erin_sd
Jan 2, 2012 07:36 PM
Tupolev22m
Sep 12, 2006 02:27 AM
crossworx
Oct 8, 2005 04:46 PM
