Couple of Questions
Old Apr 3, 2009 | 10:03 PM
FlyBoyd's Avatar
Default Couple of Questions
I am a new 2004 S40 1.9T owner and have a couple of questions...
1. How do you tell between a 2004 and a 2004.5?
2. Should I be concerned about a check engine light? i.e. misfiring, expensive repair, or could be something minor?
Thanks for the help.
Old Apr 3, 2009 | 11:45 PM
jrgillespie630's Avatar
From: Cincinnati, but somehow ended up in Milwaukee
Your model is first generation.
The 04.5 has a new body style.
check engine light could be anything. could be a gas cap up to the engine about to blow and everything in between. take it to Auto Zone and have then run it for codes and then come back and tell us what code it's reading and we can let you know.
Old Apr 4, 2009 | 01:20 AM
FlyBoyd's Avatar
Default Thanks
Thanks for the input. I will get that checked out tomorrow and report back. How do you know I have the old body style?
Also is the maintenance on a S40 generally good or is it above average expense wise?
I love the car I just want to know if it was a good choice?
Thanks again.
Old Apr 4, 2009 | 12:55 PM
Lyonsroar's Avatar
Post a pic. We can tell you old or new body style
Old Apr 6, 2009 | 02:38 PM
Exclamation
Thanks again.
I know you have the old body style because it's an 04 1.9T... the new body style doesn't have the 1.9T...
maint isn't too bad, this forum will save you a lot of trips to the stealer. you made a good choice!... google your car and look at pics..this may help with youe confusion...
Old Apr 6, 2009 | 02:49 PM
Somthngfrce's Avatar
Volvos are very particular vehicles. If you keep up on your maintenance, then should be inexpensive (figurative speaking). If you neglect it, then it's going to get expensive, but that's the same for anything out there. Parts wise,http://www.fcpgroton.com/ this is the place to get Volvo parts super cheap!
AnEskimo
Sep 25, 2010 08:32 AM
Deliverance
Mar 26, 2006 10:50 AM
mikel
Aug 28, 2005 09:36 AM
jedihookah
May 18, 2005 01:02 PM
