cv joint stuck in tranny
Old Aug 11, 2007 | 04:22 PM
billwhite70's Avatar
Default cv joint stuck in tranny
Can anyone give me a suggestion on how to get a cv joint out of a transmission. I used a puller to get it out of the hub and it was a bitch get out, I was sure I was going to strip the puller's screw but it finally budged with some lubricant. When I went to pull it out of the differential, it just wouldn't budge. I've hit it with PB-blaster and banged on it with a hammer as much as my manuevering room under the car allows. Should I keep banging away or heat it up? Has anyone run into this before? (BTW, I've pulled cv-joint off of other vehicles I've owned before and only once has one been stuck but I was able to pull it off with a really hard pull).
Thanks,
Bill
Old Aug 11, 2007 | 04:58 PM
Default RE: cv joint stuck in tranny
Have you tried going from the back side of the Axle with a BIG prybar between the transmission and the Axle?
Sometimes I have to tap my prybar between the Axle and the transmission to get it to pop out.
Old Aug 11, 2007 | 06:17 PM
I've tried to tap a couple of different prybars and a pickle fork in between the inner joint and the tranny (I banged on the pickle fork with a hammer to try to pop the joint out) but it won't go in. I'm actually pretty surprised at how resiliant the little sucker is. I imagine that the splines must be rusted in because it doesn't seem like the circlip could possibly be holding it in that tight. I imagine that if I had it on a lift and could give it a couple of full swings it "might" come loose but I only have about 16 inches to work with.
Old Aug 11, 2007 | 06:43 PM
Yes I agree it must really be in there good.
Sometimes I have to give a really good wack as well.
Obelix
Jun 20, 2022 08:40 AM
dpvovo
Feb 18, 2019 07:41 PM
ylwgto
Dec 8, 2012 12:41 PM
612diablo
Sep 10, 2011 08:07 PM
amotin
Dec 12, 2008 09:13 PM
