Driver side seat belt problem
Old Dec 1, 2013 | 03:10 PM
Newport_j's Avatar
Default Driver side seat belt problem
My driver's seat belt does not retract properly, it stays extended. it works ok as a seat belt, but it does not retract and gets in the way when shutting the door. Also, when getting into the car to start it up it is clumsy to connect since it is sprawled everywhere.
The replacement parts is quite expensive. I would like to get a used one if possible. What is the part name on a 2002 Volvo s40? I think I know where to get a after market one, but any other help in finding one is appreciated.
Thanks in advance.
Newport_j
Old Dec 2, 2013 | 08:45 AM
Hudini's Avatar
It's probably got hair and stuff keeping it from working properly. Have you tried cleaning the retract mechanism? I've seen some crazy stuff get stuck in there over the years.
Old Dec 2, 2013 | 12:22 PM
Newport_j's Avatar
Default How do I remove it
That is possible is has not stopped working; it just does not work very well. I would like to clean it. But how do I get it out of the sidebar? It is behind all kinds of plastic and stuff.
Any help appreciated. Thanks in advance.
Newport_j
Old Dec 15, 2013 | 06:03 PM
Newport_j's Avatar
Default Seat belt Tightening
I must ask this question again. How do I remove the driver's side piilar housing into which the drivers seat belt retracts?
I am not an experienced mechanhic and I need to do this to clean Volvo drivers seatbelt.
Any help aoreciated. Thanks in advance.
Respectully,
Newport_j
Old Feb 20, 2014 | 12:24 PM
Newport_j's Avatar
Default loose seatbelt on driver's side
I had my passenger side airbag deploy a few months ago. Again that was the passenger side airbag.
Now the driver's seat belt is very loose so I am wondering if that is because of the airbag deployment -although airbag deployment was on the passenger side. I know that some seatbelts have a cartridge that explodes when the airbag deploys; again, some seatbelts have that.
But my loose driver's side seat belt did not have the driver's side airbag deploy.
I am just wondering if that is the case here. Is the seat belt is loose becuase it is dirty or because the passenger side airbag deployed.
Thanks in advance.
Respectfullly,
Newport_j
afran15
May 9, 2015 11:11 PM
liweih21
Jul 3, 2013 05:12 PM
Armenian6000
Jul 16, 2011 07:10 PM
MT89
Apr 22, 2010 07:14 PM
guptash
Apr 1, 2007 12:17 AM
