Seat Belt Assembly - Driver's Side
Old Apr 19, 2010 | 07:42 AM
MT89's Avatar
Default Seat Belt Assembly - Driver's Side
Hi All,
I have enjoyed reading some of the posts as a guest for a while, so today I finally joined officially. We have a 1999 Volvo S70. We love the car, but the repair bills are kind of steep. We recently had the Seat Belt assembly go on the driver's side. They want $530+ to fix it -- most of that is the part.
Has anyone attempted to fix this on their own before? Is it doable? I can get a used part from various used parts dealers from a "non-blown" salvage for $95-125. I've looked at the connections in the car and they seem like a few bolts, but I am not a mechanic. So, kind of worried about doing some more damage.
Thanks and I'll take whatever advice someone can give. MT89
Old Apr 19, 2010 | 07:51 PM
It is not that bad at all to replace it.
Old Apr 20, 2010 | 01:36 PM
MT89's Avatar
Thanks. I sent you a separate message, but I'll post some photos. Just not sure about a couple of spots where I might run into trouble.
Thanks for the advice. MT89
Old Apr 22, 2010 | 06:19 AM
MT89's Avatar
Default Photos of issue
Here are the photos. I am particularly worried about what happens after unbolting the big bolts in the first picture. Also, not sure what the silver compressor looking thing is in the 3rd picture. Finally, not sure how to get to the bottom part of the seat belt. Volvo is usually pretty good about providing access to controls/etc., but I can't figure this one out with the power seat adjuster (pic4).
I've also received some advice about disconnecting the battery, so I hopefully don't engage the airbags.
Thanks for assistance/advice, MT89
Attached Thumbnails Seat Belt Assembly - Driver's Side-pic2.jpg   Seat Belt Assembly - Driver's Side-pic3.jpg   Seat Belt Assembly - Driver's Side-pic4.jpg
Old Apr 22, 2010 | 07:14 PM
First unplug the electrical plug. Then remove the 2 big bolts and the one holding the clamp on the cylinder looking thing. Then Pull the seatbelt assembly away from the body.
On the seat lift the front of the control panel straight up first then slide it back to unhook the cover from the back of the seat.
Not there is 2 ways it can be hold to the seat. One is just a bolt. The other is a lock that holds it. If it is the lock style there is a little rectangle that you will push in the pull the seatbelt out.
afran15
May 9, 2015 11:11 PM
liweih21
Jul 3, 2013 05:12 PM
Uel
Apr 29, 2012 06:30 PM
Armenian6000
Jul 16, 2011 07:10 PM
pram
Jun 29, 2006 11:30 PM
