engine misfire or tranny problem
Old Jul 7, 2008 | 05:51 PM
rj0828's Avatar
Default engine misfire or tranny problem
Hi,
My 2001 s40 (80k mi) check engine light went on awhile ago Now, the car is not driving right(has progressively gotten worse). It is getting rough and isn't driving smoothly(intermittently losing power?).Even though the check engine lightwent on, it felt like the tranny might be been causing the problem (long story why I think that) as when I shift gears (e.g.,from reverse to drive), it seems to be it is not shifting right. I took it to a transmission place and they said there was a problem (fluid not flowing right; possible torque converter problem) with the tranny. I took it to a place that works on volvo engines and they said the computer code said that the problem was an engine misfire and it is probably the coil. That really makes sense.
Could it both problems (I hope not !) or is the transmission place wrong. Do they actually have computer error codes for the tranny??
Thanks.
Ron.
Old Jul 7, 2008 | 07:04 PM
Default RE: engine misfire or tranny problem
I would fix the misfirng first and see from there. Also have the engine mounts inspected.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
FLENG2008
Mar 17, 2008 09:40 AM
Svtfiveoh
Dec 9, 2007 09:15 PM
Febus
Oct 31, 2007 07:37 AM
