help! s40 td 98 misfire, cold start problem
Old Mar 11, 2008 | 06:38 AM
FLENG2008's Avatar
Default help! s40 td 98 misfire, cold start problem
hi i have a 98 td s40
my first problem is in the morning it doesnt like starting, i have to crank it a few times and give it some gas for it to start, then when it does start it smokes afair bit for a min.
then once she started and we finally get moving, it will sometimes misfire at 2 certain point between 1000rpm and 2000rpm, this problem used to be just when the engine was cold but now it seems to be more frequent.
can anyone help
Old Mar 11, 2008 | 07:59 AM
Hudini's Avatar
Default RE: help! s40 td 98 misfire, cold start problem
When you say 98 td S40 does that mean turbo diesel? Or is it a petrol engine? The North American version with the 1.9L petrol turbo engine has a known issue where the fuel pressure regulator fails and causes a hard start condition.
Old Mar 11, 2008 | 08:32 AM
FLENG2008's Avatar
ORIGINAL: Hudini
yer turbo diesel 1998
any suggestions??
thanks
Old Mar 17, 2008 | 09:25 AM
Hudini's Avatar
Does the TD use glow plugs? If yes, have you changed them?
Old Mar 17, 2008 | 09:40 AM
FLENG2008's Avatar
ORIGINAL: Hudini
thanks for the reply
the starting problem was a broken wire to the g/plug
just a misfire problems now if anyone can help
DecalService
Dec 4, 2019 10:52 PM
ConkersBadBreath
Dec 7, 2014 11:22 AM
ptrccrmn
Mar 21, 2013 09:46 PM
MrCanuck
Oct 6, 2009 11:33 AM
