Engine Replacement
Old Dec 18, 2015 | 10:15 PM
Sethg04's Avatar
Default Engine Replacement
Got an 04 s40 vin 68. Wondering if a vin 52 engine would operate correctly in place of the 68.
Old Dec 19, 2015 | 10:34 AM
doing some quick research, the 52 code points to the B5254T4 (aka T2-R) and the 68 refers to the B5254T3. The biggest differences between the two engines are the turbo/exhaust manifold design and that the 52 has dual VVT where the 68 is single VVT. I've seen where people have done the swap but have adjusted the cam timing and leave the VVT unplugged (then again their goal was 400+ HP ). You may have some issues with ECU and fault codes as I suspect they use different ECU set ups. May take some more reading but you can google on the engine codes to get some insights.
Paige
Engine & Internal
Dec 3, 2010 05:06 AM
McQuattro
Jun 19, 2009 07:29 AM
Bruno937
Mar 25, 2008 08:31 AM
cj_magnatta
Mar 17, 2006 10:08 PM
