fan won't turn off
Hello,
After I turned off the car today I noticed that fan was still working.
The only way to shut it down was to remove the fuse.
In 10 minutes I put the fuse back.
It was about 55 degrees outside.
Thanks
Thanks
How long did you let it run for before you pulled the fuse?
It might run for a couple of minutes after shutting the car off to cool the car down some.
After installing the fuse is it still running?
Tech,
Thanks for the reply.
It was running for a couple of minutes. Then I pulled the fuse. After reinstalling the fuse again the fan still was working.
I pulled the fuse again, waited for 15-20 minutes and installed it back. Everything was ok then.
