help! My volvo's engine fan won't turn off
Old Jan 18, 2009 | 06:04 PM
alex00918's Avatar
Default help! My volvo's engine fan won't turn off
I have a 94 855 turbo and the enginecooling fan won't turn off. I changed the fan relay and it still has the same problem. With an electrical meter i noticed that the #1 remote cable is always sending electricity to the fan relay. Hence i think is the ECU but i am not sure, plus the ECU only tells me (by codes) faulty low fan speed. Also the car has a small short circuit that nobody finds. Please Help! (sory for my english I' am from Puerto Rico)
Old Jan 18, 2009 | 06:11 PM
Default RE: help! My volvo's engine fan won't turn off
Maybe the Coolant temp sensor is bad keeping the fan on.
Old Jan 18, 2009 | 06:27 PM
alex00918's Avatar
So you suggest i change the part....but im still thinking why the ecu doesnt detect it?
And why if the engine switch is off can it still send a wrong signal to the ecu?
Il'l chek it out...
Another question someone knows if the ECU controls the rpm gauge and the engine temp. gauge? because both failed when my fan failed....
Sory i know i should wrecked it but is my only car
Old Jan 18, 2009 | 06:31 PM
They might be connected. I would change the ECT and thermostat and see if that fixes it.
Old Jan 18, 2009 | 06:40 PM
alex00918's Avatar
I'll do it. Thanks
Old Jan 18, 2009 | 06:53 PM
Please let us know how it goes.
Old Jan 18, 2009 | 11:39 PM
JPN's Avatar
JPN
If the ECT sensor was faulty, it can send wrong signal to the ECU and then the ECU keeps the fan running even after the key has been removed.
I would try locating the short circuit first. If there is a short circuit, it could fry something you replace/repair.
See attached for the instrument gage testing details.
JPN
[IMG]local://upfiles/6892/D7CCBA7CF1BB4C3089E3A146613A90EA.jpg[/IMG]
[IMG]local://upfiles/6892/C0D6691AC5444E0586D6D9ED7D7D714E.jpg[/IMG]
[IMG]local://upfiles/6892/874755425A84487E892BEBFF67657505.jpg[/IMG]
[IMG]local://upfiles/6892/72A8502B983046D38F28790EF97C9060.jpg[/IMG]
Old Jan 18, 2009 | 11:40 PM
JPN's Avatar
JPN
The last page.
JPN
[IMG]local://upfiles/6892/455CF9B117FD4B0D99EDF23B21AAED8C.jpg[/IMG]
Old Jan 19, 2009 | 08:06 AM
Psaboic's Avatar
Did changing the ECT Sensor work? When the sensor on my sons 850 went bad, thge running cooling fan was one of the symptoms
volvoralph
Jul 19, 2016 04:19 PM
shrinking
Jun 9, 2015 09:22 PM
willymay
May 12, 2015 07:08 PM
Jackpeck3
Mar 6, 2011 08:23 PM
airapetov
Jan 29, 2006 09:56 PM
