First gen power passenger seat?
So I asked around on a Reddit forum about this because I wanted to know if the first generation (1995 to 2004) had a power passenger seat as an option because its something I'm interested in. I was told that it wasn't possible but then I came across this site which showed that it was.
https://www.copart.com/lot/70004341/...9t-ca-antelope
So was this done aftermarket or is it indeed possible to have an S40 with a power passenger seat?
2004 is an odd year since it has both the Gen 1 "2004" and the Gen 2 "2004.5" which requires using the VIN in many cases to know which parts apply. You may want to call around to a recycle yard like Erie VoVo to see if a) they have a seat that fits your trim color and b) if they have the specific wiring harness required. Then you may need to search for a wiring diagram specific to the 2004 Gen 1 to see if it has a connector listed. That's not to say that a 2000-2003 model has the same harness... Maybe you can get a copy of VIDA to research more or ask a dealer parts dept to do you a favor and check.
erelislt
09-10-2022 05:22 PM
