Front wheel hub replacement S40,2005
Old Jul 22, 2011 | 12:11 PM
Cezary's Avatar
Default Front wheel hub replacement S40,2005
Hi.
I have to replace front wheel hub on my S40, 2005.
There is only one bolt holding bearing hub with axle together and I can not find proper torque value for it. The dealer give me strange numbers "first 14f/lb and than 81f/lb and did not exlpain why two values.
Wonder if any one has instructions for replacement.
Just finished rear hubs and it was not very comlicated but the front is different.
Old Jul 27, 2011 | 08:25 AM
guinness's Avatar
dont kno much about volvos but from experiance with other cars it might just be an initial torque to break in the bearing (torque it and spin the hub around by hand a little bit) to make sure everything is seated right then crank it to full torque rating.
just my guess it might be wrong. when i did the front bearings and hubs on my jetta i just went straight to 90 ft/lbs and have had no issues
Old Jul 28, 2011 | 12:33 PM
Cezary's Avatar
Thanx.
It makes sense. I did the bearing and it works fine. Still have one more to do asap.
The torque values I have are still way off. The bolt is only M10 and if I put 80ft/lbs on it it would make a drill bit out of it. Just used my judgement and experience.
Old Jul 28, 2011 | 09:22 PM
guinness's Avatar
hmm thats weird? i thought u were describing an axle nut. holds the axle and hub together? but M10 is way small for that so now im not sure if u were talking about a front axle nut than 80ft/lbs is about right
geoduck
Jul 15, 2016 04:18 PM
puxnstx
Dec 13, 2014 11:36 AM
Volvo Newbie
Dec 28, 2011 09:00 AM
PaulH413
May 4, 2011 03:03 PM
