fuel injectors
Old Apr 2, 2026 | 08:08 PM
richard raven 1835's Avatar
Default fuel injectors
looking at replacing the injectors on my 06,non turbo,s40.does the color coding of injectors make any difference?would the injectors for a turbo engine run richer or leaner?.would appreciate any input.
Old Apr 3, 2026 | 09:40 AM
richardkonrad's Avatar
No Turbo engines require higher flow rate , replace with same
Old Apr 3, 2026 | 10:08 AM
i am experiencing some engine problems that might be lean conditions.not sure that current injectors are correct,would like to go one step richer.current injectors are brown.suggestions?
Old Apr 3, 2026 | 02:39 PM
suggestions?
In theory it does not matter what you use for injectors.
If the O2 sensor thinks it's too rich, the ECU will fire the injectors a shorter period of time. And conversely if the O2 sensor thinks it's too lean - the injectors will stay open longer. Too rich or lean long enough and codes will be set. I trust you have scanned for codes.
If you think it's lean - you should be looking at your fuel trims first - That will tell you what the O2 sensor is thinking. Then make an informed decision (rather than randomly replacing parts on a guess because you "think" it's lean)
Sure it's possible that it's lean due to low fuel pressure or any other number of reasons - but codes will usually appear.
Old Apr 4, 2026 | 10:34 AM
re hoonk,you are absolutely correct in what you say.but i am working in my driveway with limited tools and less money.i am getting a check engine light.saying #1 cyl is too lean,also get light #3 misfire if revved over 3200 rpm,although the engine feels to run fine in either case. did check for air leaks and found none.
Old Apr 9, 2026 | 10:53 AM
A common problem is the fuel pressure regulator , if you put your foot down and it hesitates than its normally the problem , but check codes first
91-740Turbo
Feb 9, 2014 08:45 PM
tdrendel
Feb 25, 2012 09:31 AM
VJZ
Jan 28, 2009 01:29 AM
ct60flyer
Nov 12, 2007 11:06 PM
cranky
Oct 26, 2005 12:25 AM
