Fuel Pressuare Test
Old Jan 20, 2016 | 09:37 AM
aerosnout@yahoo.com's Avatar
Default Fuel Pressuare Test
Hello, and Thanks in Advance, I need to check the fuel pressure in my Volvo. Will a standard fuel gage pressure tester work? Or do I need a special one or any special tools? Thanks
RD
Old Jan 20, 2016 | 12:27 PM
There's a schraeder valve (like a tire) on the end of the fuel rail that you'd need to connect into. The FP should be in the 40-50 psi range (some variance by model and FI systems)
Old Jan 20, 2016 | 11:52 PM
You might want to add a location to your profile.
If you have an autozone or oreilly close to you they have loaner tools and you can check out a fuel pressure tester that will do.
Old Jan 22, 2016 | 10:44 AM
Hudini's Avatar
Harbor Freight sells an el cheapo fuel pressure tester kit also.
brmicbman
Jan 26, 2011 12:13 PM
badfrog
Jun 29, 2010 01:28 PM
richsid
Mar 25, 2008 01:01 PM
bcullen
Nov 23, 2007 12:57 PM
willko1
Dec 13, 2005 01:38 AM
