fuel pressure regulator
RE: fuel pressure regulator
When you get the new one it comes with the mounting and everything.
This is what I do. Once you remove the Throttle cable cover and the fuel rail cover you will see the regulator on the end of the fuel rail.
Release the fuel pressure from the rail. Push the schrader valve with a rag around the end to release the pressure.
There is a clip that holds the regulator itself into the mounting. I slide the clip out and remove the regulator.
Then do the same with the new one and install it into the bracket on the car.
MntnDewMan
04-03-2024 04:05 PM
slsnumber1
03-15-2011 02:55 PM
