Hard start extra control valve
Old May 5, 2011 | 12:57 PM
balooga1's Avatar
Default Hard start extra control valve
hello,
I have had a problem with long crank in my 2001 volvo s40, I have replaced the fpr and within 6months it started again. I also cleaned the idle valve. I came across a solution of installing an extra control valve with a t piece next to the fpr. The p/n for this kit is 30662287. Just wondering if anybody has tried this method and if it worked before i spend 150 bucks on the kit.
Old Aug 24, 2018 | 07:38 AM
jgermano's Avatar
Did you ever install this Valve? I am wondering the same thing?
Old Aug 24, 2018 | 08:29 AM
before you try to out-engineer Volvo, test to see if your fuel pressure regulator is in good working order. Normally they fail when the diaphram tears - you can pull off the s shaped vacuum line to see if any fuel drips out. If not, its quite possible your problem is elsewhere - idle air valve, MAF sensor, MAP sensor, coils, plugs etc.
volvoaj
Mar 6, 2014 07:12 AM
dnarby
Jan 18, 2014 10:42 PM
Volvo840
Dec 31, 2009 12:06 PM
apfurste
Jun 26, 2009 08:02 PM
mygfslastvolvo
Nov 22, 2005 03:51 PM
