Hard starting when cold
Old Feb 4, 2008 | 07:55 PM
tr_car_nut's Avatar
Default Hard starting when cold
When starting my car in morning it has to crank several times before it starts. It cranks rather strong but has to turnover several times before it actually starts. Not sure what to do - change or test (no CEL on) since the car had a major service (plugs, timing belt, water pump) about 20K miles ago.
Old Feb 4, 2008 | 08:05 PM
Default RE: Hard starting when cold
Pull the vaccum line from the fuel pressure regualtor and see if there is fuel in there.
If so then it is bad and that is causing the long crank time when cold.
Old Feb 6, 2008 | 11:09 AM
Hudini's Avatar
Fuel pressure regulator X 2
tr_car_nut
Feb 27, 2017 08:00 PM
triggerman
Jan 4, 2012 05:17 PM
daver80
Jul 13, 2009 10:19 PM
jackopak
Feb 11, 2007 09:41 PM
jerryman
May 23, 2006 01:19 AM
