hazard switch removal
Old Jun 9, 2012 | 06:10 PM
jpravi8tor's Avatar
Default hazard switch removal
Daughter wrecked the 92 240 brick, bought a 2001 s40 for replacement.
turn signals are intermittent, will work if you barely touch the hazard switch.
How does one remove the wood grain plastic fairing to gain access to the switch assy? thanks,
Old Jun 11, 2012 | 08:59 PM
jpravi8tor's Avatar
Do I have to remove the radio first?
Old Jun 14, 2012 | 08:07 PM
jpravi8tor's Avatar
Default why no answer?
was this a stupid question?
Old Jun 15, 2012 | 03:06 PM
Johnny Hamm's Avatar
I had a non-op hazard switch and decided it was reckless not to restore it. 2000 S-40....someone had actually posted a link to great instructions and the $50. switch (volvo dealership) was installed in @ 30 min. I forget most of the procedure (sorry), but I believe that I had to remove the radio. I know for a fact that I had to remove the two self-contained vents akimbo to the hazard switch using a small slot screwdriver as directed by the link. Once you find the instructions (persevere!)---take your time and do it in a well- lit area to avoid damage to other parts. Trust me...once you do get your problem fixed, you will be glad you did it yourself. Good luck, friend.
Old Jun 16, 2012 | 11:09 AM
jpravi8tor's Avatar
Thanks Johnny!
Old Jun 16, 2012 | 11:12 AM
jpravi8tor's Avatar
found a link thanks
2000 Volvo S40 Turn Signal Problem - Sporatically ... - JustAnswer
Old Jun 17, 2012 | 02:05 PM
Cool.
denstill
Jan 10, 2022 07:55 PM
jpravi8tor
Nov 11, 2012 01:20 PM
kirks_volvo
Dec 1, 2008 02:40 PM
lynnj
Jul 10, 2008 12:50 PM
baixin02
Dec 5, 2007 01:26 AM
