Headlight Issue
Old Feb 12, 2007 | 01:16 AM
avaghela's Avatar
Default Headlight Issue
Hello,
We own a Volvo S40 (2000 Model).
Everything has been working fine; but yesterday the headlights stopped working.
We replaced the bulbs...this didn't resolve the issue. When we checked the fuse; this seems to be OK?
Any ideas? Relay? Where is relay located in S40 for headlight?
Thanks AV
Old Feb 12, 2007 | 09:07 PM
Default RE: Headlight Issue
Not really sure where it is. But look at wiring diagram it also has componant location.
http://www.volvotechinfo.com/WD123/
Old Feb 12, 2007 | 11:11 PM
avaghela's Avatar
Thanks for the reply Tech...much appreciated.
I gave the car to dealer today; and identified...
- Had to replace CEM (Central Electronic Module). Including diag + labor + parts = $500
Then, dealer informed me he had to move the power-column to replace this part. When they removed the steering column, identified the clock spring is broke. This is going to cost another $250 (inc labor) to replace; & will take 2-days for part to arrive.
Hopefully nothing else breaks now!
Not sure if the clock spring was already broke - no way to know.
Thanks for the quick diagrams - this will be helpful for the future ;-)
Thanks AV
Old Feb 13, 2007 | 12:22 AM
Did the turn signals cancel properly?
They shouldn't have to pull the column to replace it.
I have done it before without removing the column.
Old Feb 13, 2007 | 12:38 AM
avaghela's Avatar
Hi Tech,
Yes - turn signals worked correctly.
Old Feb 13, 2007 | 01:03 AM
Oh ok sometimes the little tab on the clock spring breaks and won't cancel the turn signals.
They must have broke something. They don't break easy.
Old Feb 13, 2007 | 01:43 AM
avaghela's Avatar
Hi Tech,
Thanks for your update.
I agree - I have the feeling they broke something; but obviously won't own up ;-)
Peter1234
Nov 23, 2010 01:19 PM
lamb2k
Feb 28, 2008 06:27 PM
jmc00v70
Jul 13, 2007 04:59 PM
kaki5787
May 25, 2007 11:59 PM
Repoman
Mar 9, 2007 09:29 PM
