headlight problem
Old May 7, 2006 | 09:53 PM
jojoswhip's Avatar
Default headlight problem
I just recently changed out my headlights to the ones with the black bezel for my 2002 s40 1.9t. I have a problem with the passenger side one. It doesnt seem to be fully lit. both the high beam and low beam seem to be on but dim. the left one only has the low beam on. when I turn the high beams on, my left one lights up as it should and the passenger side turns completely off for low and high beam? Am I missing something? I checked the connections and everything seems fine. help??!!!!
Old May 8, 2006 | 01:37 AM
Default RE: headlight problem
Sounds like a Bad ground.
Old May 8, 2006 | 01:59 AM
jojoswhip's Avatar
how can I fix the ground or check tosee if thats what it is?
Old May 8, 2006 | 08:41 PM
Usually the ground is screwed somewhere close to the lights.
You might also want to try checking a wiring diagram and make sure none of the wires for the new light are different from the old one.
Peter1234
Nov 23, 2010 01:19 PM
ev0lved
May 14, 2008 04:42 PM
Osiris1975
Oct 6, 2007 07:30 AM
NotoriousJMG1
May 27, 2007 02:42 AM
blueapple
Sep 15, 2005 09:37 PM
