help needed recirculate flap motor
hi guys i have a problem with my flap[8D] ( ohh err misus ) no not that one ! the one on my s40 its a 97 se with aircon the problem is when the air recirculate flap is open the motor that opens and closes when pressedclicks as if a relay or something is still trying to open it when its alreay fully open, iso to stop the clicking i have to drive about with the air recirculating on eg the flap is closed .eg the button pressed on .
can anyone tell me where i can locate the relay for this motor?
also can i just leave is disconnected with the flap open, will this affect the aircon
any advice is appreciated thanks guys
cheers mate i have actualy took the motor off and have found one tooth off a cog has broke off but i cant see why that would affect it as it doesnt slip ,it catches and closes and opens fully, ill go to the breakers tommorrow and get a new motor i also wanted to grsb therelay for the motor too while i was there just incase it was the relay but i dont know where it is??
also i thought about leaving the recirculate on but the car steams up inside
Im not sure if there is a relay for it or not.
I think it is just controlled by the climate module.
If you want to look through the wiring diagram look on this site.
http://www.volvotechinfo.com/WD123/
Also it must be the last tooth that is bad. When it gets to a certain point that is what stops the motor from going more. With that tooth missing it isn't going all the way to the point to stop the motor.
