High fuel pressure + P0026 and P0191/0190
Old Mar 10, 2016 | 05:02 AM
Continuum's Avatar
Default High fuel pressure + P0026 and P0191/0190
Hello
I have a series of P codes and weird behavior and have done a host of initial diagnostics and web searching and am scratching my head on where to go next. I hope to get some ideas and feedback:
Codes
P0171
P0191 and P0190
P0026
Car 2005 S40i 2.4L
I've researched these. The 190/191 was giving me concerns on fuel rail pressure. I had a boggy start that almost failed on day and this started me in earnest on the problem. The P0171 is a lean indicator so I surmised that the fuel pump is going.
So I made a pressure sensor fitting for the fuel rail Shrader valve and proceeded to measure pressure. The auto store indicated that nominal pressure was 35 to 41 psig. My measurements were 50 psig at high idle and 60 psig at low idle. This seemed very high so I checked and calibrated the gauge and this confirmed to within 2 psid.
I would figure the high pressure would kick on the P0190 pressure sensor light continuously but there are no check lights currently on.
So that's my situation. Lean fuel but high pressure. I'm totally perplexed. I am thinking mass flow sensor but I really just don't know.
Hope to benefit from other's knowledge.
Thank you. Best regards
Old Mar 10, 2016 | 03:11 PM
could be the fuel pressure sensor not the pump for the high pressure... for lean mixture, may not be related, but I'd check for vacuum leaks and intake leaks for starters.
MntnDewMan
Apr 3, 2024 04:05 PM
Aaron Hodgson
Oct 28, 2015 06:37 AM
James Hewitt
Jul 12, 2014 02:25 PM
GreggBz
2001-2013 model year XC70
Mar 22, 2013 08:48 AM
msocarras
Jun 2, 2012 06:55 PM
