Hood won't open
Old May 13, 2012 | 06:07 PM
Richard McKean's Avatar
Default Hood won't open
early 2004 S40
When i pull the lever inside the car to pop the hood nothing happens and i can't lift the hood to push the latch. How can i fix this? or should I bring it into the shop. Has anyone else had this problem?
Old May 13, 2012 | 10:25 PM
Hudini's Avatar
Can you get your head up under the dash to see if the cable is still hooked to the lever? I'm thinking if the cable is still hooked up then it is probably broken up front. I've never run into this and am unsure how to proceed without taking things apart.
If it's not hooked to the lever then you may be able to grab the cable end with some vice grips and open the hood. You would have to replace the cable but at least your hood is open. Just a guess.
Old May 14, 2012 | 09:43 PM
Yeah I should have thought of that. It's raining right now but ill check it out tomorrow.
JeannieBeannie
Mar 6, 2019 01:29 PM
MDUBBSS70
May 28, 2014 09:02 PM
misterbrooke
Nov 12, 2012 01:36 PM
Platinum52
Jan 10, 2010 07:36 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
