how to change fuel filter
Old Apr 5, 2011 | 06:44 PM
davidra's Avatar
Default how to change fuel filter
Hi
Can anyone give any tips on changing the fuel filter on a 99 T4 - I found a page saying the filter canister is under the rear passenger seat?? Inside or underneath the car I am not sure.
Also, do I need to remove the fuel pump fuse to depressurize the fuel system before removal, or follow any steps to prevent an airlock in the system (e.g. having a full tank)? If so, where is the fuel pump fuse?
thanks
dave
Old Apr 6, 2011 | 03:22 PM
Volvos rock's Avatar
Default fuel filter
On my 02 V70XC, the fuel filter is located under the car by the rear passenger door. it was as simple as unclip, remove and install new one. There is a strap hanger around the filter itself, and a pressure clip on the inlet and outlet side. Undo the lines first as it is easier with the strap attatched. If your concerned about the fuel pressure, disconnect the negative battery cable and under the hood on the fuel rail at the schrader valve release presure. I did not release the pressure, you may get a little spray but not much (just dont do that with a hot car). Not sure how similar the 40 is but I hope this helps.
Old Oct 10, 2011 | 03:02 PM
mike1976's Avatar
yep its under a flap buy the back left wheel
Old Oct 10, 2011 | 03:05 PM
mike1976's Avatar
Originally Posted by davidra
Hi
thanks
dave
pump fuse should be in the fuse box under the hood
marko2te
Jul 1, 2013 08:40 AM
850tony
Jul 7, 2009 03:07 PM
kpevav
Mar 30, 2009 05:26 AM
darkhorse
Aug 20, 2006 03:48 PM
