How to reach MAP sensor (pictures included)
Old Nov 25, 2012 | 01:21 PM
Buffalowings's Avatar
Default How to reach MAP sensor (pictures included)
Hi,
I am trying to replace my MAP sensor on my 2000 Volvo S40, but I cannot get to it because of the barrier on top of it which is attached to each cylinder. How do I remove this barrier? Do I pull on each connector until it comes off? I dont want to do anything to damage the vehicle.
the silver bar with the black wire on top is what I want to remove. The MAP sensor is below the bar, but the bar is plugged into each cylinder
[IMG]<a href="http://s1298.beta.photobucket.com/user/deedatch/library/" target="_blank"><img src="http://i1298.photobucket.com/albums/ag50/deedatch/IMG_1097.jpg" border="0" alt="Photobucket"/></a>[/IMG]
[IMG]<a href="http://s1298.beta.photobucket.com/user/deedatch/library/" target="_blank"><img src="http://i1298.photobucket.com/albums/ag50/deedatch/IMG_1098.jpg" border="0" alt="Photobucket"/></a>[/IMG]
[IMG]<a href="http://s1298.beta.photobucket.com/user/deedatch/library/" target="_blank"><img src="http://i1298.photobucket.com/albums/ag50/deedatch/IMG_1099.jpg" border="0" alt="Photobucket"/></a>[/IMG]
[IMG]<a href="http://s1298.beta.photobucket.com/user/deedatch/library/" target="_blank"><img src="http://i1298.photobucket.com/albums/ag50/deedatch/IMG_1101.jpg" border="0" alt="Photobucket"/></a>[/IMG]
Thanks for the input!
Old Nov 25, 2012 | 01:24 PM
Sorry, messed up the links. These should work
Old Nov 25, 2012 | 09:10 PM
GerBeGurGya's Avatar
Do not take the fuel rail out as you will take the injectors out as well.It is not necessary for the removal of that sensor.Simple unplug the connector from the top and the use a wrench to take that bolt out.After all is out you just twist and pull the sensor out it will fit right out behind the rail.
Old Apr 4, 2015 | 09:17 PM
funpanda's Avatar
What tool can I use to take out the bolt? The wrench I have is too tall and the other one is too wide.
Old Apr 11, 2015 | 11:05 PM
Hudini's Avatar
Get a short 12 point socket in 10mm with 3/8 inch drive. Also a 3 or 6 inch 3/8" extension. Place the socket over the bolt then place the extension into the socket as best you can given the angle. You should have more than enough metal to metal contact between the socket and extension in order to break the bolt loose. The fuel rail can be moved a little back too. The o-rings on the fuel inectors have a little give to them.
suhua4
Apr 17, 2021 09:13 AM
Markvolvo
Dec 21, 2013 08:12 PM
b00ks
May 15, 2011 08:39 PM
AnEskimo
May 16, 2010 06:19 PM
meerkat
Mar 7, 2008 09:52 AM
