Hub Press
Hub Press
I need to press a front hub assembly out of my 2006 s40. Does anyone know if the major chains (AutoZone, O'Reily, Advanced Auto Parts, Pep Boys) rent out Hub Sharks or Hub Grapplers. I need something that will press out the entire hub assembly. The hub assembly is one piece and can't be pulled.
Thanks
Thanks
This is overkill if you only have a single need. But if you do allot of work then:
6 Ton A-Frame Bench Shop Press
$70 bench top press
$70 bench top press
Volvo240guy
07-30-2006 03:28 PM
