I tore a bolt. How difficult is fixing it?
Old Apr 30, 2019 | 05:34 PM
mcfe's Avatar
Default I tore a bolt. How difficult is fixing it?
I wanted to take off the preheating plate to have a view of the exhaust manifold and how it connects to the rest of the exhaust system. But I had an accident. One of the bolts closer to where the cat is connected to the manifold was in a tight space and my wrench essentially was bending it while unscrewing and it tore off, leaving the rest of it inside...Now I know this won't cause any major issues, but now it bothers me that I did that.
I can't fix it myself, but I have to ask...will a potential mechanic have to lift off the whole engine to basically...bore through the hole to remove it + possible rethreading?
Old Apr 30, 2019 | 06:16 PM
habbyguy's Avatar
This kind of thing happens all the time, and there shouldn't be any reason to have to pull the engine out. You will probably have to remove the exhaust system south of the manifold to drill out the broken bolt.
Old May 3, 2019 | 11:50 AM
pierremcalpine's Avatar
Welcome to the club...the club of those who have broken awkward to access broken bolts, that is. Sometimes mechanics can weld something to the broken bit to help get some leverage and turn it out, other times they will drill. They'll have a solution for you, don't sweat it.
I did something similar last night: I overtightened one of the two long subframe bolts (the ones that are accessed through the hole in the control arm (the bolt is above)). Stumped on what to do next. I share your pain.
edvard
Sep 1, 2019 11:27 PM
pierremcalpine
May 5, 2019 09:48 PM
Rick Almeida
Aug 29, 2017 07:26 AM
Mikenem
Nov 10, 2013 01:29 PM
nitrosport
Feb 23, 2013 07:49 PM
