View Poll Results: Idle
0%
0%
0%
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Idle
Old Jan 25, 2021 | 03:55 AM
Odeey's Avatar
Default Idle
Please help Volvo S40 it's starting fine,but after some time it's drops the idle like it's gonna cut and it does more when I press accaralater
Model 2003
Old Jan 25, 2021 | 08:47 AM
think air, fuel, spark here. Most likely causes are 1) weak spark (check plugs/wires/connectors to the coils). Any check engine codes for misfires? 2) fuel and air need to be a correct mix. Any intake air leaks - ie torn boots/vaccuum lines? any signs of an exhaust leak? (S40s often have issues with the flex pipe ahead of the cat - you can hear it from under the car) After that, it could be failed component but futher testing would be required - is the fuel pressure ok? does the behavior change as the engine warms or does the temp gauge wander (suggesting a coolant temp sensor issue)? Other volvos models have issues with the electronic throttle mechanism - but afaik, that's not an issue with the Gen1 S40s.
Common S40 issues can include 1) fuel pressure regulators (usually cause long cold cranking) 2) wire harness to the coils / old plug wires ' old or incorrect plugs 3) engine coolant temp sensor issues 4) intake air leaks (anything rubber can tear) 5) exhaust leak at the flex pipe 6) other miscellaneous engine management sensors like O2 sensors etc can fail but usually throw a check engine code.
Old Jan 28, 2021 | 06:29 AM
Odeey's Avatar
Thanks mt..
And yes the behaviour occurs when the engine is warm and when I'm pressing fuel pedal...
Old Jan 30, 2021 | 12:01 PM
Odeey's Avatar
Default S40
Can someone help please
i need a new FPR for S40 2003
​​​​​Need a site that has fast delivery
Michael Moser
Oct 21, 2012 10:39 PM
91shelby
Aug 3, 2010 07:55 AM
dipfrog
Oct 23, 2009 10:31 AM
kevmcrae
Apr 25, 2009 11:25 PM
joker834
Sep 22, 2006 08:43 PM
