Instrument cluster problem
Old Aug 14, 2021 | 11:56 AM
LucasArts547's Avatar
Default Instrument cluster problem
Hello to all got one question.
I have a Volvo s40 2005 2.4i...
Took the car to the shop to get mileage correction done.. Long story short, got the car back with a broken instrument cluster, when it is plugged in it only displays engine light, nothing els works its dead blank. I was told to buy a new instrument cluster and it will work, so I did that but upon plugging it in it does the same thing by only displaying engine light... Not it was tested and shown that it works when I bought it. Any info on why it does that and how I can get it to work please?
Thanks.
Old Sep 12, 2021 | 12:56 AM
Wade b1971's Avatar
Default IP and passenger side locks &win inop 05 S40
Thanks.
I am having the same issue.Bought the car, doing a full stereo upgrade, Put car back together, started right up, system sounds great, but no IP nothing...except check eng light. And passenger side doors are non responsive ie. (Locks and windows). Any luck on your end?
Old Sep 13, 2021 | 12:13 PM
habbyguy's Avatar
Double-check the fuses. It's really easy to blow one when doing a stereo install. Also look for the obvious problems like plugs that weren't reconnected, or ground wires that were left unattached. It's human nature to believe that couldn't have happened, but it does, all the time, even to the best of us (whoever that is). ;-)
Old Sep 13, 2021 | 12:52 PM
Wade b1971's Avatar
Once again I have disassembled most of the dash area, removed the instrument panel, checked plugs, about at whits end. The thing that I'm not sure about is the high speed and low speed can bus wiring that is not being used now that I removed the factory stereo system. I have also noticed online that it is possible that the computer may need to be reprogrammed.
dmtri07
Mar 23, 2023 11:30 PM
marceys60
Sep 20, 2013 03:19 PM
Ashokan1
Nov 15, 2010 09:17 PM
chadman551
Dec 19, 2009 07:33 PM
Davidjwhitcomb
Feb 7, 2009 12:37 PM
