volvo 850 instrument cluster problem
Old Dec 16, 2009 | 08:00 PM
chadman551's Avatar
Default volvo 850 instrument cluster problem
so earlier nothing on my instrument cluster would work, and i cleared the codes with a OBD2 scaner and they were fine, but after that i replaced a couple bulbs on the cluster earlier today, and it stopped workng and now the little display in the bottom center of the cluster doesn't lite up and none of the gauges work anyone, and i checked all the connections to see if i plugged them back in and a cant figure out what's wrong and all i can see is the time on the instrument cluster
Old Dec 19, 2009 | 07:25 PM
frustrator-bolt's Avatar
Obviously check fuses first. Next try spraying your pin plug connections with electrical contact cleaner. Lastly when all else fails you may try to find a replacement at junk yard or on Ebay. Turbo or non turbo clusters are plentiful there for cheap.
Old Dec 19, 2009 | 07:33 PM
boxpin's Avatar
Disconnect your battery, wait about 10 min then connect and test again.
If you need a cluster PM me, I have two. One is European.
airics
Sep 12, 2012 12:28 PM
volvo5volvo
May 29, 2012 05:46 AM
PavelG
Mar 18, 2012 01:11 PM
chadman551
Mar 4, 2010 07:28 PM
chadman551
Nov 9, 2009 11:16 AM
