Intake or Exhaust?
Old Mar 31, 2011 | 08:57 AM
xxdaly7xx's Avatar
Default Intake or Exhaust?
I have an 05 S40 2.4i and I want to increase hp, would you recommend installing an aftermarket cold air intake or buying an aftermarket exhaust kit? Intakes run around 300 and Exhaust are about 700. Let me know what you guys think
Old Mar 31, 2011 | 03:24 PM
ibanez958's Avatar
I recently installed the k&n cold air and full catback exhaust on a friends 05 S40 and it ran great except fuel economy went to the ****ters. Took it to a dyno and got a proper map on it and all was good. After about 40k of driving however it began to have multiple problems with fuel pressure and cvvt probelms. Does it sound awesome and haul ***.....you bet it does.....worth the headaches......not so much, imo that is
Old Mar 31, 2011 | 07:59 PM
xxdaly7xx's Avatar
Damn thats too bad, those are overly priced as well they want like 350...Im thinking about getting some piping, hose clamps and a filter and making my own..good or bad idea?
Old Apr 2, 2011 | 11:27 AM
mmnewcomb's Avatar
K&N makes a short ram intake for the 2.4i, not an actual cold air intake last time I checked. You'd probably be better off making your own, that's what I plan on doing. K&N wants almost $300 for a short ram which is crazy.
EuroSportTuning.ca has a really nice cat-back exhaust system for $675 or so. It's mounts real easy and goes to a dual output.
ElevateCars.com also has a similar cat-back system but it's more expensive.
Old Apr 4, 2011 | 11:15 AM
ShowTek's Avatar
I made my intake for about 30 dollars, and same thing as Eurosport and K&N..
they want 300 dollars for a piece of pipe, and filter. Think about that.
Old Apr 4, 2011 | 11:18 AM
ShowTek's Avatar
Also custom exhaust, much much cheaper, same basic result.
Old Apr 4, 2011 | 09:40 PM
xxdaly7xx's Avatar
You made your own for 30 dollars? Damn! Did you notice a decent result from it or na?
Old Apr 5, 2011 | 07:17 AM
mmnewcomb's Avatar
How $30? I'm building my own and got the mandrel bent piping for $50 by itself. And the bought an injen filter for $40
Old Apr 5, 2011 | 10:26 AM
ShowTek's Avatar
Well i cheated a bit, i got a Spectre filter from a friend, so that's like 20-30, keep in mind i have a 01 s40, and then i got the bottom part of my air box that ran into the side bumper and ran a pipe(Bendy) through the current pipe(Hard plastic) and pushed it to my blinker, long story but my father took my car to pep boys once and they broke the mounts on my blinker so there is about a space this big "l l" and then i attached a little scoop thingy i found in garage. Not much difference, other than the noise is awesome.
On another note though, my idle went from 800ish to 590 and i get check engine lights for misfires, but i don't think that these two events were related and that my car is just acting up.
Old Apr 5, 2011 | 10:29 AM
ShowTek's Avatar
Oh and for the noise, i meant the recirculating valve, for your N/A it'll make the engine a bit louder and more throaty. I've heard that cone filters that are not pressurized can make your lower end pick up a bit bad, and that panel filters work better. But it all depends where the filter is i guess.
Since i have turbo i can't really have a CAI.
Old Apr 5, 2011 | 03:01 PM
mmnewcomb's Avatar
Right. I have the 2.4i so I need the cold air. I'm routing mine down in the drivers side behind the bumper since I got my own tubing. All I could find for sale were short ram and I don't want that at all. Plus I enjoy doing my own work when I can.
Old Apr 5, 2011 | 03:21 PM
xxdaly7xx's Avatar
What's the difference with the short ram from the one for the turbo model
Old Apr 5, 2011 | 03:38 PM
mmnewcomb's Avatar
I'm not sure if there is a difference since it just comes straight out by only a few inches. You'll definitely see a performance increase at least due to the fact that the engine would be getting more free-flowing air, but it's still going to be hot air.
I'll take a lot of pictures when I build my CAI (should be the end of this week) and make a tutorial if you wanna wait till then.
Old Apr 6, 2011 | 06:00 AM
xxdaly7xx's Avatar
Alright thanks a lot thatd be great
Old Apr 6, 2011 | 12:07 PM
ShowTek's Avatar
Well for a turbo there is almost no point in having a cold air, since a turbo uses exhaust gas's to spool up, heating the housing unit and therefore heating the air from the intake.
Old Apr 6, 2011 | 01:32 PM
mmnewcomb's Avatar
Right but daly7 was talking about options for his 2.4i not a T5. So in our case cold air makes a huge difference.
Old Apr 7, 2011 | 06:36 AM
  #17
xxdaly7xx's Avatar
Does it really make a huge difference bc its only suppsoed to dd like 6-8 hp right?
Old Apr 7, 2011 | 11:03 AM
  #18
ShowTek's Avatar
And honestly it might make 6-8hp difference if you keep your car up to spec and always tuned, I.E a weekend car. But say daily drive, not so much. And intakes don't make a difference really until you get an exhaust system to match, then they'll let the car make more top end power.
Old Apr 7, 2011 | 11:04 AM
  #19
ShowTek's Avatar
Also, makes a very big difference where you live too, i live in Texas, where the roads are about 120-125 degrees and tarmac can be up to 150.
Old Apr 7, 2011 | 11:05 AM
  #20
ShowTek's Avatar
Also to make sure you get the best you can, you should probably heat wrap your exhaust manifold since most intakes for 2.4's run in front of them, also i think i just got an email saying that Eurosport came out with a 2.4's intake.
