Intermittent Oil Light
Old Mar 28, 2014 | 04:27 PM
oldguy99's Avatar
Default Intermittent Oil Light
I have a 2002 S40 with 89K miles. Last week after an hour of stop and go driving the oil light started flickering and going on and off irregularly. I checked oil level and it was correct, and took the car immediately to my mechanic. He checked out the sensors, wiring, and oil pump and all tested no problem, and he noted that there were no error codes registered. He suggested I keep an eye on it, and I drove it for four days, about 200 miles, with no problem. This morning I was driving it to my transit station and after a block the oil light started to flicker again. Has anyone had a similar problem to this? Thanks!
Old Mar 28, 2014 | 04:53 PM
difflock54's Avatar
What grade of oil are you using and is it synthetic or mineral type?
Old Mar 31, 2014 | 11:23 AM
oldguy99's Avatar
Default Oil light problem - what oil
I have been using 5w30 synthetic and live in a very temperate climate.
Old Mar 31, 2014 | 06:00 PM
difflock54's Avatar
At 89k it should be good on 5w30 synthetic.
Does she use much oil between changes?
Have you had the PCV system checked for any signs of positive crankcase pressure. May be starting to clog up.
Any yellowish creamy, mayo' like residue showing on the dipstick?
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
gargoyle
May 30, 2014 07:28 PM
MrSplean
Aug 13, 2010 02:43 AM
gerryb
Mar 8, 2009 10:00 PM
