key trouble maybe??!!??
Old 01-08-2009 | 06:17 AM
rupert77's Avatar
Default key trouble maybe??!!??
i have posted a few questions regarding having issues about getting no power to my fuel pump!?! Is it possible that my key may be faulty and the car isn't reading the key thus not sending power to the pump in order for the car start, or also something to do with the anti-theft system?? Does any one know if this is what happens if the car doesen't read the signal from the key? (not send power supply to the fuel pump). have changed pump, checked all relays + fuses also everything else electrical is working!!!!
Old 01-08-2009 | 08:27 PM
Lyonsroar's Avatar
Default RE: key trouble maybe??!!??
If the car doesn't read the signal from the key, the immoblizer system would be activated causing a light (car with an x through it) to flash on the dash and no start. I know from experience! Tech remembers
As always, if I'm wrong, correct me tech!
Old 01-11-2009 | 11:57 AM
rupert77's Avatar
yes you are right, looked it up in the manual. With me switching relays around and getting them to work again has sent power to the pump but the car is still not starting., I have replied to your other post explaining that i had to get a diagnostics test done and tghe reading was faulty camshaft sensor so i will keep you posted on the outcome whenever i get my new one ok ,thanks v. much...
Old 01-12-2009 | 04:56 PM
Lyonsroar's Avatar
Ya, I know! Stupid Volvo charged me mucho dolores to fix that immobilizer!
tomc761
04-10-2019 04:57 PM
Cambridge Volvo
02-01-2010 01:29 PM
jlcq244
11-18-2005 05:55 PM
c5bum
03-16-2005 02:07 PM
Trader4Less
01-08-2005 11:02 PM
