Looking for a little pep
s40 have a boost gauge? if not put one in. My s60 was making around 4psi max, so I knew something was not right. should be 7-8psi. I replaced the TCV with an OEM unit from FCP. I also coughed up the coin and put in 93 octane instead of the usual 91 i do. I saw 6psi yesterday. Also make sure your tires up to the proper psi.
I had to travel yesterday for work and the turboturd put a smile on my face in the left lane.
You don't need new fuel injectors. You can have them cleaned for about $15 each if you remove them yourself. I wouldn't worry about it unless you develop a lean miss.
My mistake on the Turbo Control Valve. That is what it's called on the 2005+ cars. On the 2000-2004 it's the Boost Control Solenoid. (BCS) Boost Control Solenoid
You might try an Auto-Rx treatment. This will decarbon the piston ring packs and restore lost compression.
Ahmed
06-02-2014 06:09 PM
2k2wranglerx
12-18-2010 08:15 AM
atomicbob
07-08-2009 11:28 PM
