Low windshield washer fluid light?
When the winshield washer on my 2002 Volvo s40 is empty (or very low) does a light come on, on the dash?
I think so and the image resembles a sprinkler, sprinkling water.
Any help appreciated.
Thanks in advance.
Respectfully,
Newport_j
Thanks in advance.
Respectfully,
Newport_j
Okay, since the low windshield washer fluid light comes on when I start the car (if only a for a second) then it cannot be the low windshield washer light. Is there a sensor that is not working and must be replaced? Again, my car is a 2002 Volvo s40.
Thanks in advance.
Respectfully,
Newport_j
Thanks in advance.
Respectfully,
Newport_j
Assuming that the level sensor is a float style then if the float is stuck it will never turn on the low level light. If you have run it dry without receiving the low level indication then you most likely need to either replace the sensor or if you remove it you may be able to clean it to free up the float.
Jimbo_Jones
Dec 5, 2010 11:01 AM
