missing vacuum hose?
Old Jun 14, 2024 | 10:09 PM
erubin's Avatar
Default missing vacuum hose?
2007 Volvo S40, 2.4L Engine B5244S7. Non turbo automatic trans.
The EVAP Purge Valve P/N 8653909 has a 2 pin connector and a hose running to the bottom of the intake manifold (near the throttle body). This relatively small hose is connected and good. But on the bottom of the valve there is a ~3/4" nipple but nothing connected to it. Occasionally it makes a suction sound when the engine is idling and sucks air into this valve. Should there be a hose attached to it? If yes, where does the other end of this missing hose go? The image shows the nipple facing up but it actually faces down when the purge valve is mounted (with a rubber sleeve) to a steel bracket.
Old Jun 15, 2024 | 02:53 PM
erubin's Avatar
Did some research and it appears that I'm missing hose 8658723. Dont know where the other end attaches. Hose #6 attaches to valve #15. Where does other end of hose attach?
Old Jun 16, 2024 | 02:12 PM
erubin's Avatar
I've searched for an hour and still dont see where my missing hose would connect. One end goes to the purge valve. The other end I dont see anything within 6" that has a fitting. Any suggestions?
Old Jun 16, 2024 | 06:53 PM
erubin's Avatar
I found the hose. I removed the battery and battery tray and the hose was there!
Old Jun 19, 2024 | 04:41 PM
yep, one line is the vaccuum hose to the intake, the second hose goes to the back to pull the stored vapors into the intake when the valve is opened. if that back hose is off or torn you would likely get a small evap leak CEL code.
Sajor
May 20, 2022 12:34 PM
BPATR1CK
Jan 22, 2012 10:51 PM
VolvoViking
Apr 4, 2010 05:35 PM
skooter66
Jul 5, 2009 11:38 AM
safari
Dec 3, 2007 12:04 PM
