Are my struts toast?
Preface:
Well, I fixed one problem and probably created another problem. As previously mentioned in another thread, I took my Volvo in and found out that I need to fix one of my strut mounts and CV joint. I bought the strut mount and half shaft. I was able to do the strut mount replacement myself and I'm going to have someone else put the half shaft on. Anyway, I had my car suspended a couple days before the parts came in. During that time, it's been pretty cold, even though my car was kept in the garage. After I put everything on and lowered my car, it seemed fine.
Problem:
A few days later, I decided to drive it and I noticed my car bouncing a lot. Something definitely wasn't right. After I got out, my car was basically dropped in the front. As I jacked it up, I noticed a lot of popping. Is that in any way related my CV joint that I haven't replaced yet? Or is it possible both stuts went bad at the same time and now basically going to replace them with these:
http://www.fcpgroton.com/product-exe...ein+Touring%29
Problem:
Wow, thanks for the quick reply! When I took off the strut mount, the spring was definitely fine. Didn't think of the sway bar. Would that make the popping noise like air was getting pushed back in as I lifted the car? What exactly would I be looking for on the sway bar since that's a new one for me. Thanks again.
