Need help with a trouble code...
Old Feb 20, 2012 | 12:39 PM
abrusnahan's Avatar
Default Need help with a trouble code...
Hi guys,
I have a 2000 Volvo S40 (turbo) and I am getting a P0102 code. Being that the care is new to me, I do not see any noticeable performance issues. The only indicator is that the car takes 2-3 seconds to crank normally which isn't normal.
I got it scanned, and the guy gave me a receipt with everything it could be, and I am hoping you all can help be hash it down to a few possibilities.
Please let me know.
Old Feb 21, 2012 | 03:42 PM
hickman123's Avatar
maf sensor low volts. i have read that a stuck close iac will cause this it is on the throttle body pry it open with a screw driver if it is stuck close and clean and lube it. but these guys had an idle problem. or you should check that the maf is getting good power and grounds.
Fuzz51
Jul 13, 2012 09:48 PM
meatpotatoes
Jun 10, 2012 08:18 PM
miguelito22
Apr 12, 2008 08:57 AM
Lukester
Nov 12, 2007 01:04 PM
B1mmer
Dec 18, 2006 11:24 PM
