Need Window Regulator
Just in case someone looks this up in the future and needs info on this subject the best price I found on a replacement was here:
http://www.partsgeek.com/catalog/200...regulator.html
Really? $180? Try our sponsor next time...fcpgroton.com They are a tiny bit cheaper...you could have replaced almost three regulators for that price...
http://www.fcpgroton.com/product-exe...ndow+Regulator
I haven't had time to try and install it yet. It has been raining the past two days so I didn't want to attempt it. I sure hope it fits correctly or I will be pissed after paying $140. Thanks everyone.. I'll keep you updated. It's too bad the stock regulators are junk. I've never had a problem with any of my other cars.
Well the stock regulators are made the way they are because of laws.
Just like the garage door openers that have to have sensors.
The regulator is designed to break if it gets closed hard on something. This way if a kids arm or your arm gets closed in it it will break instead of cutting it off. Or causing alot of damage to you. I think they should have done something like when it sees excessive power draw it should just reverse instead of breaking.
Yes it sucks it has to be this way but just like on a lawn mower that has a sticker with a hand by the blade and it is crossed out. They designed it because something happened.
Ok, I got the regulator installed yesterday. I looks just like the picture posted above. You use the nuts as seen in the photo to attache the motor to the inside of the door instead of the bolts that came OEM. I also had to cut the connector off the car and connect their connector in it's place. Good think I had wire nuts on hand. But it functions perfectly and hopefully will last a loooonnng time. The motor is slightly louder than OEM but not bad at all.
I also had to install a news lens on the headlight... what a pain. Had to loosen the bumper to pull it slightly away from the car. Had to jack it up and remove the wheel on the side I was replacing. PITA just to swap a lens... but if I had to do it again it would be easier because the instructions are not that great but now that I know...
