New member- issues with 2007 S40
Old Dec 23, 2021 | 10:44 AM
Rocko's Avatar
Default New member- issues with 2007 S40
As I come to complete stop..sometimes I lose all power to engine and all gauge lights come on... if I turn it off and turn it back on all is okay... it happens a few times a week.
Old Dec 24, 2021 | 03:04 PM
sounds like a relay is sticking (possibly inside the CEM?), a wiring/connector issue or you have a faulty connection in the ignition switch that periodically open circuits. Best to have some diagnostics done by a pro before you get stuck in a dangerous situation.
Old Dec 25, 2021 | 09:45 AM
richardkonrad's Avatar
Agree Get a proper diagnostic done as the fault should be there even if it does not happen when you test , without that it could be many things, I would not attempt it with my simple scanner , you may be lucky in replacing a bad connection etc , in these cases I first check all connectors to look for corrosion , never worked for me in all the years exept for a bad earth but then everything is dead , which is not your case
talltine
Jun 1, 2017 11:20 AM
spideyUSA
May 2, 2013 04:40 AM
NixonS40
May 16, 2010 06:05 PM
2007~S40~2.4i
Mar 29, 2007 01:02 AM
vovonub
Sep 13, 2006 02:22 AM
