new S40 owner
The turn signal housing is held to the headlight housing via a phillips head screw. You can see it looking straight down from the top/back of the headlight housing.
Loosen the phillips head screw on the back side of the headlight housing. Pull straight forward on the turn signal housing. Do not pull up/down or left/right. It comes straight out same as the headlights shine. It's not difficult once you see it.
