o1 s40 heater/ac problem
The blower kept revving up and down regardless if it was on hot or cold and it wouldn't switch from hot to cold or cold to hot without shutting off the car. I got a used transistor from the junkyard. This stopped the revving up and down but still won't switch from cold to hot. I know it could be faulty since it was used but could the problem also be the controls?
There is an arm that snaps or gets out of sync that controls how wide open the vent is. It's on the passenger side footwell panel, around where the radio is. There is a procedure to sync it back up with the 0 position once fixed. I'll see if I can scrounge up a link. I know there is a pdf on one of the popular boards. I think it's MVS or UK boards.
This one is for the arm - it has several links to pdfs on the post - http://www.matthewsvolvosite.com/for...hp?f=8&t=34858
This one is for the random controls - which might be your problem if it does in fact switch - see the two links to 30forty50 and swedespeed on post 11 - http://www.volvoforums.org.uk/showpo...5&postcount=11
ycartf
05-06-2013 11:19 AM
