Ok I made a rookie mistake.... BTW I am a noob to here.
Old Jul 13, 2010 | 02:17 PM
REVV AUTO's Avatar
Question Ok I made a rookie mistake.... BTW I am a noob to here.
2001 S-40 I took the VVT pulley off W/O marking the position. How in the world am I going to be able to reinstall without getting the cam timing off. I am at your mercy here. PLEASE HELP ME............
I am a veteran to other 4ms but new here. Let's see how my new family treats it's fresh meat............................hehehehehe.
thanks in advance, DD
Old Jul 13, 2010 | 08:22 PM
As long as all went as it is supposed to when you took the pulley off it locked in the proper position.
You will need to make a tool like in this post. That will lock the backside of the cams.
https://volvoforums.com/forum/general-volvo-chat-5/cam-locking-tool-fabrication-38396/
Once the cams are locked then you can put the pulley back on and line the timing mark up where it should be then tighten the center bolt to 90Nm then install the cap for the center and torque to 35Nm. Make sure the pulley is locked into position. If it is then you should be fine with it all done.
If you removed the Non VVT pulley then the screws get torqued to 20Nm
Old Jul 14, 2010 | 02:54 PM
jks2's Avatar
Tech to the rescue, as always.
Old Jul 15, 2010 | 09:55 AM
REVV AUTO's Avatar
no wonder you have a lot of posts...............thanks guys it went well and car is down the road.........!!!
DD
Old Jul 17, 2010 | 07:12 AM
Congrats!
Andrewcoxon
Nov 3, 2012 11:17 PM
chris123
Oct 2, 2009 05:14 AM
JimKW
Sep 7, 2009 05:20 PM
chef
Dec 15, 2008 10:11 AM
