Oxygen Sensor Changed and Lights Stills On
Old Feb 19, 2019 | 09:43 AM
rudva's Avatar
Default Oxygen Sensor Changed and Lights Stills On
My 2005 S40 turns on the check engine light, the codes P0031, P0037 sensor 1 and 2 are readed. I change the sensors in town the dealer recommends bosch or original one. Then I realize that the car uses bosch ones the I decide to use the same. But the lights remains on. I check for bad contact, wires, etc and everything is ok.
Any ideas what could happen?
Old Feb 19, 2019 | 10:16 AM
are you saying you cleared the codes and they returned or did you not redo the OBD2 scan and clear the codes after installing the new parts?
Old Feb 19, 2019 | 12:14 PM
rudva's Avatar
Yes,
I clear the codes. I was expecting to do not turn on after a 40-60 miles... but
Old Feb 19, 2019 | 02:10 PM
habbyguy's Avatar
Check fuse F33. Those codes are for failures in the heater circuit for the sensors, and they both share the same fuse to power that circuit.
Old Feb 19, 2019 | 03:21 PM
rudva's Avatar
Thumbs up I will
Ok, I will check that today. I let you know guys. Thanks!
Chynabell13
Jun 21, 2019 08:50 PM
raygnlz
Oct 26, 2009 08:09 PM
gilber33
Oct 19, 2009 07:01 PM
contsi
Jun 19, 2008 05:07 PM
DrDootz
May 5, 2006 01:39 PM
